Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router isis
Switch:1(config-isis)#spbm 1 multicast spb-pim-gw controller enable
Variable definitions
The following table defines parameters for the spb command.
Variable |
Value |
<1-100> |
Specifies the isis spbm instance-id to create the spbm instance. |
controller enable |
Enables the SPB-PIM Gateway Controller. |
